Problem with Test
*** Edited Message ***I once had that problem and it seemed to be fixed when in the "Publish to HTML" option I believe I checked "Include Title Manager" or "Include JavaScript Title Manager" depending on the version you have. You could also trying checking "Title Manager Frame" which states in the Help file as "This option enables you to store all variable data locally, instead of within the browser's cookies. It is suggested to select this option if your title contains a large number of questions or variables. Selecting this will increase your title's performance if your title contains a significant number of questions or variables."Do you have either one checked?Other than that, I don't know.Regards,Edited By: bruman on 2008-9-24 12:39:25
