Problem with Test
September 24, 2008 12:00 AM
Pls. describe "stalls". What do you have after the test, if anything?Is there a javascript error? (yellow triangle in lower left corner for IE.)What version of Lectora?Did you mean Run mode? Edit mode is where you do all the development work. Test is not active in Edit mode, just in Run, Preview or when published.
