Problem with "Done Playing"
"Done playing" actions don't work if you're publishing to HTML because the browser has no way of knowing when the media is done playing.The easiest workaround is just put a delay on the action to show hidden content, with the length of the delay being the same as the amount of time it takes for the mp3 file to play through.Hope this helps!Laura
