problem in emailing results
June 24, 2008 12:00 AM
Hi,I have lectora version 2008. I tried emailing the test results. It is showing the warning as " A program is trying to automatically send e-mail on your behalf. Do you want to allow this? If this is unexpected, it may be a virus and you should choose "No". Is there any possibility to change this prompt?Also is there any possiblity to prompt for mail ID before it sends the result? Please give your suggestions.Regards,T.Vanitha
