Print is not working
Another option that I found on the forum last year when I switched from EXEs to HTML formats was this, not sure if it will fix your issue though, but you can try it.Have a button on a blank page in a new window. The blank page has an action on show to open and print a PDF, if that is what you are trying to print. I can't take credit for that but have found that it works if needed.Otherwise, I am fresh out of ideas. Anyone else?
