posting variable into email body
1. Learn how to put everything in one variable. The best example is how Lectora does Page numbering - Tools menu > Page Numbering tool. Study how it puts all the different pieces ("Page", the actual current page number, " of ", number of pages) into one variable.2. Once you have that, use that technique to create a variable that has all your stuff in it just how you want. Use the same syntax you are using above. Then in the email address field put Var(your variable).
