Login Sign Up
ELB Learning Logo
Topics
Members
Website
Knowledge Base
New Topic
Menu
  • Topics
  • Members
  • Website
  • Knowledge Base
  • New Topic
Archived
Report Abuse
Position Attribute for Group
@vivek
February 23, 2012 12:00 AM
Hi,
It would be nice to have Position (X & Y) attributes to Group. Having that we can then use the Move To action. I found this use case which expresses the desire for the same http://www.lectora.com/forum/f5/using-move-grouped-object-6194/
Thanks,
Vivek.
Vivek vivek
@vivek
View Profile
More From Vivek
Essay Quiz - Max. Answer Text Length does not take into account "Enter" Key Presses
July 29, 2014 Reply 0 Upvotes
Newer DocType for Pages Generated Using Lectora's Publish Option
July 24, 2012 Reply 0 Upvotes
Regarding Detecting Variables in External HTML Objects
May 15, 2012 Reply 0 Upvotes
Essay Type Question - Maximum answer text length?
April 10, 2012 Reply 0 Upvotes
Disabled Attribute to Radio Button and/or Form elements
February 14, 2012 Reply 0 Upvotes
How to Disable Radio Buttons?
February 10, 2012 Reply 0 Upvotes
Lectora Online / Lectora Inspire Course Compatibility?
January 19, 2012 Reply 0 Upvotes
Regarding Importing Lectora Library Object
Equation Editor in Lectora Online.
Regarding Availability of Equation Editor in Lectora Online 1.6
January 10, 2012 Reply 0 Upvotes
How To Enable Events Tab in the Video Properties of Lectora Online?
January 9, 2012 Reply 0 Upvotes
Join The Discussion
Sign Up Login
