Need Help using Training Partner 2008+
Hello
I’m having problems getting SCORM1.2 content to work on Training Partner 2008 +,
The client has complain that the content that I’m sending is not working for them they have 2 complains
1) They are getting an error message say that it is unable to find an API adapter
2) after the page loads all they see is the title name( no images or nav).
I’m not too sure what is going on, is the first time that I work with Training partner 2008 +. I have worked with other LMS providers without having any problems.
the settings I’m using are
Lectora X vX2a (6966)
SCORM Options
SCORM 1.2
The publish course will be presented ina separate window than the LMS
The published course will prompt to restore the last viewed location within the LMS
Options
Use JavaScript Title Manager
Generate Short ASCII HTML page names
Use Web 2.0 Style pop ups
Any help , info or documentation about Training Partner 2008+ is very appreciated
P.S: I have also tested the content in ADL and another LMS and it works perfectly.
Adriana
