Narration timing when not using Flash Audio
I know you can put event markers in Flash audio to use as cues for actions, but what if you have a narrator and want to publish your project for use on an iOS device?
iOS doesn't support Flash (at least not natively), so I'm looking for another way to time events to go along with a narrator. I've been told that using timers isn't a good idea because, depending on the user's download speed, timers have been known to not work accurately and timing gets off.
Has anyone else dealt with this issue?
