Mute background audio!
October 14, 2009 12:00 AM
Cannot read all text here due to bug in the forum. Would you go to your post above and delete the image. I think that way all the text will show in these boxes.
Hard to tell exactly what the problem is without seeing the course. Suggest you use the File menu > Export > Zip and post that to the Files section of the Lounge and then post here that you did that.
