Muliple Graphics for Form Elements in same title? (like radio buttons)
March 26, 2012 12:00 AM
Hi Guys,
Been a little while since I last posted, however I ran nto what may be a simple problem to fix, I just can't figure it out.
Is there a way to use multiple grpahics for Radio Buttons and Checkbox Buttons in the same title.
Example say I wanted to use blue radio buttons for a multiple choice interaction in 'question 1', normally I would set this in the title properties 'Form Elements'.
..but if I wanted to use red radio buttons for a multiple choice interaction in 'question 2'. I can't set this the same way or it will overwrite the settings globally within the course..
..so Is this possible?
My added complication is I need to stay 508 and Mobile compliant in my resolution. (if there is one)
Any ideas?
/Andy
