MP3 Sound Not Playing
April 10, 2007 12:00 AM
What mozilla version are you trying to run the audio in? I use 2.0, and it does not ask for any audio at all. Usually when mozilla asks for plugin, chances are that the plugin you look for is suggested by mozilla itself. Just click on the green icon, or in top right corner in the yellow bar. If mozilla cannot find a suggestion for it, then you should try to avoid the browser when possible.We have had the same things for video-playback however, but installing whatever mozilla suggested was enough to get it working.
