Using Actions
Hi thereI have built my content so that the text blocks build up on-screen to voiceover. This may include say 5 text blocks with 5 voiceover.The first method of this was to create 5 pages and build up the text in each page whilst playing each subsequent voiceover. This worked well, and using a reset button, would replay the sequence over again. The drawback of this was the title and the graphic flashed each time a page was loaded - not so good.I did stumble across using the layers for the text blocks turned off, and when the voiceover finished, use an action to then show the next text block, and play the next voiceover. Again, worked a treat - no flashing of title or graphic. It even packages as CD-ROM perfect? NOT SO, this will not package as SCORM and run, giving the error that actions will not play off of multimedia elements (or similar).Not only that, using the button to jump to the same chapter, section, page now doesnt work either.Has anyone come across such issues and worked around them? Thanks
