Menu Problem
Yes, you just need to put the menu object in the desired folder at the top level so it shows up on every page. There should be a drop down in the properties for that menu that you can select either Entire The Entire Title or For This Chapter. You need to select For This Chapter.Yes, you just need to put the menu object in the desired folder at the top level so it shows up on every page. There should be a drop down in the properties for that menu that you can select either Entire The Entire Title or For This Chapter. You need to select For This Chapter.
