Menu does not left align
After creating the Menu with Menu Creator, from Menu Style tab, uncheck "Create Menu from table of contents", select left align from top bar, click OK.
When you see Menu on the page the Menu content looks centered. Seems like an issue but wanted to put it out there.
Discussion (1)
@cgsapovadia - Thanks for your post - I am able to recreate this issue and will be sure to document this is a bug so it can be fixed for a future update.
Thanks again for the feedback.
