Customize trivantistestresults.html to block users from copying
Thanks Laura! I will try that and will post it back later but seems like that should be the easy fix. Thanks for the reply.
Chet
cgsapovadia said:I want to know if anyone has any tip to pre adjust lectora settings to have trivantistestresults.html page in SCORM package with no right click option and also make sure user can not copy the questions by printing or any other way. OR I would say create a simple PDF file that does not have any option but to just view. Currently I publish the file to SCORM, unzip the file, edit trivantistestresults.html with adding "no right click" java on top and remove print button from bottom. This is little time consuming process and need real good tech skills for newbie. I really appriciate any help. Thanks, Chet
