Thanks Shawn!
I have used the java script in course title and it works great for the pages but the problem is really with the result page where we display the answers with feedback after they complete the test. I think this file is generated through the Lectora and we have to edit the code to block the right click and also if we want to block the CTRL+C CTRL+V options. I think I will try what Laura said above and see if that works first because I want to avoid using custom coding due to most of ID and ITD will not feel comfertable editing the code. Great idea though about blocking the content.
Thanks,
Chet
