Matching question distractor problem
I have used the matching question in some quizzes I have created and used the option to include distractors. I am getting the same problem described in "Matching question lines exceed boundaries".I have one matching pair, two left column distrators and two right column distrators, so 6 options in total. I am using International publishing suite v2006 SP2. I have published to html and when you try and match up a distractor the line does not connect to the options but appears over the left column, very much like in the picture in the topic above. I don't have any images on the page that would interfere with the lines.Anyone got any ideas/solutions? (previous solutions given in above topic not suitable)
