Matching question distractor problem
April 13, 2006 12:00 AM
Okay - I have an update on this problem! I've discovered that this problem only occurs when you set the title to appear centered in the browser window...if it's left-justified in the browser window, the lines do draw correctly. The Trivantis tech support person I'm working with on this is going to report this issue to the developers to see what's up and hopefully create a fix for it.Okay - I have an update on this problem! I've discovered that this problem only occurs when you set the title to appear centered in the browser window...if it's left-justified in the browser window, the lines do draw correctly. The Trivantis tech support person I'm working with on this is going to report this issue to the developers to see what's up and hopefully create a fix for it.
