Lectora/JavaScript/Variables problem
Ok first thing you need to do is make sure that the variable is loaded. This is a common problem I run into, depending on when the javascript is executed. Right now it sounds like the variable isn't loaded so you cannot manipulate it. Also the caps get stripped in javascript when Lectora writes the code. Try this:
Code:
