Lectora 208 dropping Audio?
When publishing the program to HTML format there is a compression tab that shows up on your publishing popup box. Turn off the compression for the audio files on this tab by un-checking the box and you should be able to hear your files once you publish.When publishing the program to HTML format there is a compression tab that shows up on your publishing popup box. Turn off the compression for the audio files on this tab by un-checking the box and you should be able to hear your files once you publish.
