Learning Flash
September 20, 2007 12:00 AM
Another suggestion for you would be to check out learnflash.com - I had taken some Flash training at the local college and as they say it's a very deep program. I found the tutorials from learnflash.com to be very direct and easy to follow. One of the great things they offer are free tips on how to do things in flash. You just need to register to receive their email. Might be worth exploring to see if you can pick it up easily from the freebees. However, as another person said, you first want to get a good feel for layers, keyframes, etc. Barnes and Nobles put out a book a couple of years ago on Flash under their 'In Easy Steps' label... good source to learn the basics. Good Luck to You - I know the feeling of how confusing it can be to learn Flash. I can only say, stick with it and 'when the lightbulb goes on', you'll know it!Christine
