Issues with deleting unused resources
December 2, 2021 12:00 AM
When I delete an unused resources from my scenario, the media library panel closes and CenarioVR freezes for around 30 seconds. When I try and re-open the panel after this, it's very slow and unresponsive. I have to close and re-open my scenario to get it running smoothly again.
Does anyone have a similar issue?
Thanks,
Jack
Discussion (4)
I can't seem to replicate that, tried on several scenarios. anyone else see that?
I don't remember seeing that particular phenomenon. I've had many times where CenarioVR would pause for 30 seconds or longer, then behave unpredictably. Browser console indicates the common "JavaScript went crazy" problem--the browser is suddenly using all the CPU in can grab and it seems to be related to demanding JS.
@jackgayler , have you tried in a different browser?
I use Chrome by default. In Chrome, I tried using a different scenario and it works OK. So it may be a scenario specific issue.
UPDATE - It does seem to be a scenario specific issue. Even if I try and look at my resources, it gives up. Then when I finally get in a delete the unused item, it gives up again. This scenario is approx 2GB in size.
@Johnb, I can send my HTML package to support if you like.
