How to build so users' progess is saved?
November 1, 2007 12:00 AM
Hi Carol,We're using Lectora 2006 and we've had success during SCORM publishing by checking the Lectora option, "The published course will prompt to restore the last viewed location within the LMS"...(This is on the SCORM Options tab). If it's recording the right location in the LMS, it should take the user back to their last viewed location, regardless of whether they're using a different browser or machine for that matter, upon next login.To add further customization, you can also create a course-specific message for this purpose (a grouping called publish strings in Lectora). Got to File->Preferences->Publish Strings. The default is set to "You have previously been in this lesson.Would you like to return to the last visited location in the lesson?" We tweaked this a bit for one course we're developing: "You don't have to remember everything. We made a note of where you were the last time you were here. Do you want to go there?" The user can then select OK or Cancel, meaning that the OK option takes them to the bookmarked location and cancel takes them to the beginning of the course.Hope this helps.
