@hplrsmom
November 1, 2007 12:00 AM
What LMS are you using?What LMS are you using?
Use Current Date to Trigger Action
Custom Advance by Enter / Spacebar causing unresolved destination error
Check all functionality
Help! Properties dialog box not popping up
