Help with Overlapping Audio
October 12, 2008 12:00 AM
Sir Wise, do you have your objects grouped? Much easier to stop the group vs stopping each object individually. If you haven't already, try 2 groups - audio, text blocks. Actions on each button are on click, hide group text block; on click, stop audio group; on click, play audio file; on click, show text block. Forgive me if you're already doing this, but it doesn't sound like you are. Should increase the speed.Russ
