Help with Overlapping Audio
1. Only set the main audio to Initially Visible and Auto Start. This will make the main audio play upon entering the page. Other six audios should not be set to Auto Start, but should be "visible".2. Have the clickable image Stop all other audios (main + other five), and have it Play the audio you want to play.There are other methods you could use (hide and show the audio using audio visible properties, etc.). Conditions of variables could be employed as well. Clicking each image would modify variables, and actions would play and stop certain audios based on these.
