Help with Overlapping Audio
I wish there was a global action to stop all other audio, or to stop last audio played. I have noticed a problem in this... I have 5 buttons, 5 text blocks, and 5 audio files. Each button is set to hide 4 of the audios and the text blocks, and show one text and play one audio. It works, the problem is that it make everything run sooo slow. The page takes long to load and their is a long delay every time you push a button.I wish there was a global action to stop all other audio, or to stop last audio played. I have noticed a problem in this... I have 5 buttons, 5 text blocks, and 5 audio files. Each button is set to hide 4 of the audios and the text blocks, and show one text and play one audio. It works, the problem is that it make everything run sooo slow. The page takes long to load and their is a long delay every time you push a button.
Discussion (1)
I wish I were writing with a solution- but I am just writing to say that I am right there with you Roxanne. I'd love a global stop all other audio action, because I find myself in the same type of situation. I know FLASH has a StopAllAudio feature that I have used in the past.
