Help with Overlapping Audio
NP. Don't feel like a doofus - I've been there, believe me!Sometimes simpler is better....but sometimes not.I go for simpler first. Sometimes you can use so many variables that things get confusing, especially if others need to work in the file. And sometimes the variables/conditions don't work as you think they should.Rule of thumb - to truly verify, conduct final testing via HTML publishing (displays in a browser window), not Lectora preveiw. Lectora preview is a great quick preview for functionality, etc., (and I do use it), but use HTML preview for final testing, and then via a test web site. If it works from the test web site, odds are that it will work on the LMS.Glad it worked out. Take care.Edited By: JDH on 2008-10-12 23:27:16
