General Capabilities Question
July 24, 2008 12:00 AM
Well, there is a pretty simple way to do this.Add an action to a next button or a question process button on the page. Set the action to on: "show" action:"show" target:[text box to show] then go to the conditions tab of the action and set the variable to the question variable (you can look it up by going to the properties of the question) and set the relationship to "Is not Correct", then it will work.For more clarification, just ask!
