General Capabilities Question
I concur. You can definitely have more than one action on a button. You put put one action on the button properties, then use the "Add Action" feature for additional actions.I concur. You can definitely have more than one action on a button. You put put one action on the button properties, then use the "Add Action" feature for additional actions.
