FLV problem
Hi All,I'm embedding an flv file in one of my pages. In the same page while the flv is running, I want to display some message in a text block just above the animation or an image above it. In the preview mode it is working fine. but when i go for an HTML publishing, the flv file runs over the text block.I had the same problem while using the flash files. But that was resolved by setting its wmode parameters. However, in flv files, there is no option for setting the parameters.Is there any way to overcome this problem?
