Flash to Lectora issues
October 3, 2007 12:00 AM
Part 1: Well, you can put hidden graphica on the page and have them appear. With Lectora 2007, you can move those graphics to any desired coordinates. That should come close. It is relatively easy to do.Can't help you with Flash, but in the LectoraExchange.org under the Tools section, there is a paper about using Javascript with Lectora. Tells you how to access variables. Also search this forum using the search button at the top.
