image resolution maximum?
Hi there. I'm wondering if anybody knows if there is a maximum resolution that Lectora will display?For example, when I use Flash, I use 72 DPI, because I know that Flash will not display at a higher resolution, and thus using higher resolution graphics is a waste (since they are larger files).Is there such a limit with Lectora?Edited By: leafeater on 2007-11-16 14:39:13
