Flash to Lectora issues
October 3, 2007 12:00 AM
I you are using Lectora 2007 you can use the flash command. It's not documented very well but it may be what you're looking for. Place a lectora button on the stage. In the on click tab put "Flash Command" as the action, put your .swf as the target. Then you have a drop down of some options - so you can get a variable value from flash and use it, or you can use lectora to set a variable in flash etc... Take a look and see if that will help you solve what you are trying to accomplish.I you are using Lectora 2007 you can use the flash command. It's not documented very well but it may be what you're looking for. Place a lectora button on the stage. In the on click tab put "Flash Command" as the action, put your .swf as the target. Then you have a drop down of some options - so you can get a variable value from flash and use it, or you can use lectora to set a variable in flash etc... Take a look and see if that will help you solve what you are trying to accomplish.
