Flash Issue
Does one folder contain one series of screen shots? So for each example you get a folder of .swf files? If so that could be kind of messy. For it to work you would probably need to drop the folder in your lectora generated html folder. Then in lectora put in some external html code to point to the first .swf in the series. If you'd like to zip up one of the folders of .swf's I can take a look at it and let you know the easiest way to get it to work....Edited By: Hemingway on 2006-11-20 16:4:11
