Flash Issue
November 20, 2006 12:00 AM
I know this is awfully late for a solution, but I just found a fix for Camtasia created SWFs. This will allow you to use the Camtasia playbar and Table of Contents.Add every Camtasia-created .js, .swf, .xml, and .gif file to your title. There should be at least 6 files. On the page you want the movie, add an animation object. For the animation file, choose the xxxxxx_controller.swf you attached in the previous stepResize the animation as appropriate.That's it. As long as the other Camtasia files are attached to the title, it should work fine.
