Login Sign Up
ELB Learning Logo
Topics
Members
Website
Knowledge Base
New Topic
Menu
  • Topics
  • Members
  • Website
  • Knowledge Base
  • New Topic
Archived
Report Abuse
Flash Issue
@photoman52b
November 20, 2006 12:00 AM
Well good luck, if all the .swf files are the same size it is possible to build one controller to work for all of them, you would just load the controllers into lectora and tell it which .swf to play via the Lectora parameters tab. May be more work that you want though. Have fun.-Mark
photoman52b photoman52b
@photoman52b
View Profile
More From photoman52b
Page Size Sniffer
May 7, 2007 Reply 0 Upvotes
Page Size Sniffer
Page Size Sniffer
Page Size Sniffer
Page Size Sniffer
Page Size Sniffer
Page Size Sniffer
Page Size Sniffer
Drop Shadows
April 21, 2007 Reply 0 Upvotes
Drop Shadows
Drop Shadows
Transition problem
November 14, 2006 Reply 0 Upvotes
Transition problem
Transition problem
Transition problem
Transition problem
Join The Discussion
Sign Up Login
