Flash Issue
I have found that if I create a Flash video with controllers, the controller file has to be at the main level in order to display. The other files should be in the images folder, but you have to manually put the controller file at the main level. I have found that if I create a Flash video with controllers, the controller file has to be at the main level in order to display. The other files should be in the images folder, but you have to manually put the controller file at the main level.
