Login Sign Up
ELB Learning Logo
Topics
Members
Website
Knowledge Base
New Topic
Menu
  • Topics
  • Members
  • Website
  • Knowledge Base
  • New Topic
Archived
Report Abuse
Exit Title/Close window does not work
@dojacobson
November 5, 2008 12:00 AM
Hi all,I'm experiencing a weird issue with the Lectora 2008 Exit Title/Close Window button/action.It works perfectly on IE6+, but fails to function on FireFox, Chrome and Safari. Did anybody come across this issue earlier?And more important... how can I solve the issue?Thnks!Do
dojacobson dojacobson
@dojacobson
View Profile
More From dojacobson
Advanced Resource Manager
June 19, 2009 Reply 0 Upvotes
Show/Hide objects in left-hand pane
May 6, 2009 Reply 0 Upvotes
Certificate doesn't display in IE6
May 25, 2009 Reply 0 Upvotes
Custom result pages layout lives its own life...
May 19, 2009 Reply 0 Upvotes
Lectora crashes using Custom Test Results
November 6, 2008 Reply 0 Upvotes
Test results skipped
September 30, 2008 Reply 0 Upvotes
Lectora/JavaScript/Variables problem
May 28, 2008 Reply 0 Upvotes
Join The Discussion
Sign Up Login
