Drag and drop not reseting
Hi,
I'm still pretty new so probably a simple answer to this question. I have a page with a drag and drop question. I have two images which a student will drag to the drop zone and once they drop it in a message will appear notifying them of some detail. However when the close that window I want the image in the drop zone to reset and go back to its position before the student drops the next image.
How can I do this? Read a few post here about this but don't really understand them yet. Still trying to work all this out :)
any help will be appreciated!
Thanks
Discussion (5)
Or you can try Change Contents with the target as the question (not the question variable). I think this will leave the # attempts in tact but I have not tried it. Oh, to reset, you set the Question to an empty variable.
It seems "Display message" cannot be done "On: Timed interval". So a Submit button is a good solution. You can still do it "On: Timed interval" but it requires a few more steps to get around that restriction.
You can use your own variable to count attempts instead of the built-in attempts functionality. That variable won't be influenced by resetting the question:
1. Create a variable, e.g. "q1_attempts", initial value 0
Add actions to your Submit button
On: Click
Action: Modify variable
Target: q1_attempts
Value: 1
Type: Add to variable
On: Click
Action: Show
Target: Correct Answer
Condition: Only if "q1_attempts" "Greater Than Or Equal" "2"
Tim
Hi Jeremy. It's been a few weeks. Did you get an answer to your question? I've been wrestling with drag-and-drop questions. I solved your issue by having a 'submit' button and adding the action 'Reset question'. My problem is that I want to do this and still have it recorded as an attempt. I want to display the correct answer after 2 attempts, but resetting the question also seems to take the number of attempts back to zero. Cheers, Glenn
What does not work? What are the symptoms?
Feel free to zip the page and send to below addr. I will respond within 24 hrs.
:mad:
I keep working on this, but nothing seems to work. My drag and drop questions all work on other pages, but they are drag and drop with text.
I have one drag and drop with 4 images, 2 correct, and one background on which to drop the correct answers with only one drop zone.
I've deleted the page and rebuilt it - didn't work.
I've copied the one that worked and tried to replace things - didn't work.
I've moved the Reset button under and over the question - didn't work.
I created a Submit button. The Reset Question still didn' work.
I created a new Lectora project to see if there was something wrong with my project. No, the images just will not reset.
I even tried scaling down my images and changing from .png to .jpg and back.
I did send my project to the technical crew and received an e-mail from someone's question that didn't apply.
I've call the toll free number and the regular number. It seems their system is stuck in voice menu mode. I couldn't get in.
Help please!
