disabled state for custom check boxes and/or radio buttons
October 23, 2024 8:13 PM
Under certain circumstances, I would like to disable my check boxes and/or radio buttons in an exam.
When I use the default cb/rb and set to disabled: the image appears grey is unclickable, still shows the user's selection.
When I use custom cb/rb from the test&survey menu: disabled state will prevent clicking but it doesn't change the appearance & the mouse still switches to the pointy finger.
I've tried modifying the appearance using js/css but so far haven't had any luck.
I'm open to any suggestions on how to get this to work. 🙂
Here is a website that has some great CSS for custom Checkbox Buttons
https://css-tricks.com/the-checkbox-hack/
There is even state for Disabled.
Thank you for sharing the website. I didn't use the content from here but it did make me reconsider how I was approaching checkboxes. Now instead of the built-in Lectora custom checkboxes (which are actually images) I've taken control and fully customized them with CSS (& a little bit of help from ChatGPT). Now they are looking and working exactly how I want them to.
Here is my css solution in case it may be helpful to anyone else:
/* Common styles for both checkboxes and radio buttons */
input[type="checkbox"], input[type="radio"] {
    width: 20px;
    height: 20px;
    margin-right: 10px;
    cursor: pointer;
    /* Remove default appearance */
    appearance: none;
    background-color: #fff;
    border: 2px solid #333;
    position: relative;
    transition: border-color 0.3s ease;
/* Specific shape for checkboxes (square) */
input[type="checkbox"] {
    border-radius: 4px;
/* Specific shape for radio buttons (circle) */
    border-radius: 50%;
/* Add a smaller teal box centered inside the checkbox/radio */
input[type="checkbox"]:checked::before, input[type="radio"]:checked::before {
    content: "";
    position: absolute;
    top: 50%;
    left: 50%;
    width: 12px; /* Smaller box size */
    height: 12px;
    background-color: #6CBDB6; /* teal fill */
    transform: translate(-50%, -50%); /* Center the box horizontally and vertically */
    transition: background-color 0.3s ease, transform 0.3s ease;
/* For radio button, keep the smaller box circular */
    border-radius: 50%;
/* Optional: hover state */
input[type="checkbox"]:hover, input[type="radio"]:hover {
    border-color: #888;
/* Optional: focus state
input[type="checkbox"]:focus, input[type="radio"]:focus {
    outline: 2px solid #007bff;
/* Disabled state */
input[type="checkbox"]:disabled, input[type="radio"]:disabled {
    background-color: #e0e0e0;
    border-color: #CCC;
    cursor: not-allowed;
/* Keep the smaller teal box visible for disabled and selected state */
input[type="checkbox"]:disabled:checked::before, input[type="radio"]:disabled:checked::before {
    background-color: #95A9A7;
