Custom hot spot Questions
The question wizard is nice and really easy to use, but I am not a big fan of the 'hot spot' questions that the wizard creates. What I would like to do is create my own custom hot spot type questions. How I want to do this is maybe put an invisible object like a rectangle over a specific section of an image and set that invisible object so it will record as the correct selection for the question. Can this be done? and if so what is the best way of accomplishing this? I also eventually would like to put 'the invisible object' that I talk about over a specific section of a .swf (flash) so when a certain area of the flash project is clicked on Lectora records it as the correct or incorrect answer.
Thanks!
-Dkeil
