Clicking sound between screens
June 4, 2008 12:00 AM
I think your refering to the mouse click noise that happens in Internet Explorer. Unfortunately I think you can only disable it under sound/audio options of the windows control panel on your own machine. Not in Lectora for all users.Only thing I can suggest is creating your audios a bit louder (if speakers are turned down a bit the click wont be as harsh), or make your pages longer to have less clicks.
