Click Bullet Reveal
Essentially I am trying to create a click bullet reveal where by you have a list of items and each time you click on an item in the list text or an image appears.I can create this if its an image i want to appear by setting the change contents action. I can't however create this if i am using a text box. You can only select images when using the change contents action?????HELP!
