Click and proceed without using buttons
October 21, 2009 12:00 AM
Hi - I'm back again,
I tried to use the keypress action in HTML. It works so far but if the user has to klick on a flash movie you have to klick somewhere on the page to be able to use the keypress action again. We tried to work around this problem, but couldn't find a propper solution. It's the same with pressing a button and using a keypress action afterwards. You have to klick on the page, befor your course knows the keypress action again. So my question is - how do you show your objects?
I still don't wanna show every object in the beginning. Do you use a button to "move on"? I'm a newbie in programming and wolud like to know, how you show your contents.
Thanks for any help
Julee
