Problems with publishing to HTML
Hi Ellen,
if you double-click your object you get the window for properties. There you can choose if your object will show up automatically in the beginning or not (sorry I don't know the correct wording in lectora because I use the german version - it's a checkbox on the left side). I dind't check this and forgot to set an action as well. That's why I could see my objects in lectora but not after the export to html. Nothing told my object to show up
Unfortunately we experienced another problem. If you use IE 6 or IE 7 you might have problems with your obejcts as well. We couldn't find a proper solution for that problem yet. The reason could be the file format *.png.
Hope I could help you
Greets Julee
