Can't make a question worth more than 1 point (weight it)
February 26, 2013 12:00 AM
I have a previous title from X6 that has been published and working fine for months. I opened it in 11 and made a minor change (not to the exam properties or question properties) and after publishing and taking the exam I get a error message saying:
"LMSSetValue Error cmi.core.score.raw to [115]invalid argument error"
This happens if I get 100% on the exam, the "results pop up says I got a score of 115%. Under these circumstances the exam results are not captured by the LMS.
If i deliberately get less than all answers correct, i.e., 80%, all works well and the score is captured by the LMS.
Some of my exam questions are "multiple choice" and have a "Point Value" of 2. I changed the test so all questions are 1 point and get a [145]invalid argument error.
No errors reported when I publish or do an "Error Check"
Corrupted exam? Ideas?
Doesn't someone from Lectora jump in and help with some of these posts?? Seems like a good business practice.
Discussion (2)
Hi Steve,
Would you be willing to send us your title so that we can take a closer look? Our Test department has not been successful in recreating the errors you're describing, so this would be helpful in getting to the root of the problem. You can zip your title and send it as an attachment to support@trivantis.com (place Attn:Laura Michalow in the subject line).
I apologize for the problems you're finding - we are reviewing the forum posts and researching any documented issues. To receive the best support possible in the future, you can also submit these types of bugs through our Support line. This ensures that the issue is documented and that you are contacted by someone on the Support team who can give you additional information on the problem at hand.
Thanks,
Laura
