Button Wizard Problem
September 14, 2005 12:00 AM
I haven't had anyone else report this problem and I wasn't able to replicate it going through the steps you mentioned. Can you try creating a new title, using the "new title" tab from the opening dialog? This will create a title with a single page and nothing else. Try using the button wizard from here. Start with adding one of the premade buttons from the "Stock button from clipart option". Then, if that works, try the "Cutstom color button with text" option.I haven't had anyone else report this problem and I wasn't able to replicate it going through the steps you mentioned. Can you try creating a new title, using the "new title" tab from the opening dialog? This will create a title with a single page and nothing else. Try using the button wizard from here. Start with adding one of the premade buttons from the "Stock button from clipart option". Then, if that works, try the "Cutstom color button with text" option.
