Button Wizard Problem
September 14, 2005 12:00 AM
I hardly ever use the button wizard but needed a quick button for an elearning project I was creating. I started the button wizard and chose custom color button with text, single button, changed the button text to "Submit", chose green with an Arial 12 point font, and allowed it to size the button to fit the text. I received the following error:"The width of the button will be greater than the page you are putting the button on. Please adjust the width of the button, the font size, or the amount of text on the button."The page is 780 x 640. I tried everything to get the button wizard to generate the button but kept receiving the above message. I wanted the button size to be around 25 x 25.Next I tried to use the button wizard to select a stock button from clipart. Once I selected the button Lectora crashed on me. At this point I figured there is some kind of problem with the button wizard and it wasn't being caused by something I was doing.I am using Lectora 2005 with SP3a (2546) installed. I am running it on a 3.8GHz, Pentium Xeon, 2Gbyte RAM, Windows XP Pro computer. Has anyone else experienced a problem with the button wizard?
